Why Vacuum Gripper ?
The vacuum gripper features a built-in air supply capable of up to a 5kg payload. This compact electrical gripper is easy to move, and simple programming makes it quick and easy to redeploy for greater production flexibility.
Specification
Rated Supply Voltage | 24V DC | ||
Absolute Maximum Supply Voltage | 28V DC | ||
Max negative pressure | -55kPa | ||
Air flow (L/min) | >4L/min | ||
Weight (g) | 610g | ||
Dimensions(L*W*H) | 122.5*91.6*75mm | ||
Payload (kg) | ≤5kg | ||
Noise Level(30cm away) | <65dB | ||
Quiescent Current(mA) | 20mA | ||
Peak Current(mA) | 500mA | ||
Communication Mode | Digital IO | ||
State Indicator | Power, Working Status | ||
Feedback | Air Pressure (Low or Normal) |
