Easy to use
Free GUI for easy programming
Light weight
2.2kg
Reaptability
0.2mm
Speed
500mm/s
Easy to use
UFACTORY uArm Studio offers a new way to program the robot arm without code. Simply program the robot with colorful blocks. Then UFACTORY uArm could repeat intended paths in just 10 minutes.
Support Multiple Platform
UFACTORY uArm also has the Python SDK. A fully open-source software platform offers more flexible way to integrate the robot arm into your own system.
Lightweight
Crafted from Aluminum and CNC cutting, UFACTORY uArm weights in less than 2.2kg, and it is the best choice for testing tasks.
Capacitive Stylus
The special design structure makes the capacitive stylus easy to touch and swipe, which is completely suitable for touch screen and button testing.
Durable Design
Additional attention is paid to the gearbox. The hardened steel gears with low backlash provides 0.2mm repeatability and 4000h’s life cycle. 12bit absolute encoder makes the robot joint precise enough without compromise.
